91 Users Online (90 Members):
Forums >> Revit Building >> Technical Support >> finish/ material schedule
I am wanting to create a finish schedule that has always been done in CAD. I would like it to reference the MARK/ KEY in the schedule and drawings. I am attaching a PDF of what is done in CAD in the past and is what I would like to replicate.
So do you want a dumb schedule or a smart one?
This could be smart as a multicategory schedule using the same shared parameters assigned to your model elements.
Obviously, as a dumb schedule, you can just do it in a drafting or legend view as you did in CAD. Or you can create a schedule key using a category that is not normally used in your project. You can find threads here about using a schedule key.
sorry for not clarifying. also I am using 2013 & 2014.
I would like it to be as smart as possible. meaning that I would like the marks on the schedule to match the tags on the
drawings and the use of any other categories provided.
Here is a description of using a multi-category schedule:
http://docs.autodesk.com/REVITST/2010/ENU/Revit%20Structure%202010%20Users%20Guide/RST/index.html?url=WS46b90c3cb2c58cad1cb25f1fc7fa49ed4-7fed.htm,topicNumber=d0e17289
NOTE: You need to create shared parameters and assign those to all elements to be scheduled. You can assign those as project parameters picking the multiple categories.
Finish Material Schedule |
Tue, Nov 29, 2005 at 12:31:59 PM
Schedule material mark in door schedule - Revit 2014 |
Fri, Jan 19, 2018 at 2:57:03 PM
Revit 2016 Room finish schedule and material schedule |
Thu, Mar 9, 2017 at 3:41:41 PM
Key Schedules/Finish schedule |
Thu, Jul 8, 2010 at 1:35:21 PM
Finish Schedule |
Mon, Aug 10, 2009 at 6:25:50 AM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
