34 Users Online (32 Members):
Forums >> Revit Building >> Technical Support >> Seat count in bench family
Hi, I've created a simple bench for stadium type seating. My intention is to have the following:
a) Have a user-defined seat width (or lineal length of bench per person)
b) be able to stretch a grip and have the bench length adjust to the nearest seat width
c) be able to schedule the benches in the project to get a total Lineal Feet of bench and total Seat Count
So far I have been able to achieve half of this. I have built in a parameter for user defined seat width. I have been able to use a user input for desired length and it adjusts to the nearest seat width defined (it's supposed to be able to stretch, but when I stretch it the family implodes for some reason...). What I have not been able to figure out is:
a) how to fix the stretching feature
b) be able to have some way to schedule the lineal feet and seat count.
The length and seat count is not a major deal, however, since the stadium seating is symetrical, so I really only have to figure half of it. Using a spreadsheet it only takes a little while to figure the total length, which I can then break down into a total seat count, but it would be great to be able to fix the family and share it here for others to use.
Can anyone take a look and let me know what I've done wrong, or generally explain how I could achieve this?
Thanks!!!
-Phil-
Are you using a line based family with a nested seat family?
No, I believe I have it as a floor based. Never thought of using a line based though... I assume that's where you would suggest starting over ?
Actually a floor based should still work. But I probably would use a line based family. Then it could be straight or curved. There are several youtube videos on creating and using line based families. In addition to those, check out this thread on AUGI. I think this guy used a curtain wall <<< I never would have. http://forums.autodesk.com/t5/Revit-Architecture/stadium-seating/td-p/4613003
That's definitely an interesting way to go about it! I finally got mine to work, aside from the fact that you cannot create a bench with fewer than 3 seats/spaces. My draging trouble I think was due to too many reference planes being "strong, left or right" references. Once I eliminated all but the side opposite the origin it worked. Being able to schedule the seat count ended up being because I did not have the settings correct in the shared parameters in both the family and project. I am now able to place, drag, (far as I know) adjust dimensional characteristics and schedule (calculating: total # of seats, total LF length, total count of same length benches). Now I just need to get it to where I can rotate using the space bar before placing, and then maybe add a mirror/flip feature, also being able to mitre the end would be nice. Attached is the updated file. I also plan to have a little better bracket that's more realistic, but maybe this way people can edit the bracket themselves as desired to fit whatever manufacturer they're using.
Maybe next I will try this as a line based family. Thanks!
Sweap bench around line |
Mon, Apr 8, 2013 at 9:35:01 AM
Can't amend family size in model |
Mon, Mar 19, 2012 at 9:19:56 AM
Locker/bench combo for 9+ |
Mon, Mar 10, 2008 at 3:01:40 PM
Repeat Object Within Family/Type |
Fri, Feb 1, 2008 at 9:40:17 AM
Nested Family Count in Table |
Mon, Jan 15, 2018 at 11:47:52 AM
Members: | 2019209 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
