53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Surface orientation in panel by pattern
Thu, Apr 24, 2014 at 6:02:35 AM | Surface orientation in panel by pattern
robest
Hi all,
I've got a divided surface on which I'm hosting a space frame panel. The space frame has a surface above it to which I want to apply a exterior material too - but the orientation of this goes a bit weird when the panel is applied. See attached for the panel (ok) and the applied panel (messed up). The material has a surface pattern (model lines) which is what you can see is rotated all over the place...
The points driving the surface are hosted on the adaptive points with an offset.
Thanks for any pointers!
Revit 2014
Pattern Based Panel - Rotation Error
Tue, Feb 16, 2016 at 9:35:07 PM
Parametric Curtain wall panel in divided surface
Sun, Jan 31, 2010 at 8:08:55 AM
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:21 AM
Surface pattern wont align
Sun, Nov 9, 2008 at 3:16:05 AM
Surface pattern
Mon, Sep 10, 2007 at 11:18:02 AM
Page generation time: 0.8313
