Forums >> Revit Building >> Technical Support >> Stairs and plan regions (cut height)
41 Posts No Rating |
I know this has been addressed before, but it's been several years since the last post so I wanted to see if anyone has figured out a viable solution to this, or has it been improved and I'm missing something?
I want the cut height of my stairs to be different that the cut height of my overall view range. I made a plan region around the stairs with a higher cut height, it does not change the appearance of the stairs. I made sure my region was much larger than the stairs. If I change the cut height of the entire view the stairs show as desired (the rest of the drawings is undesirable though).
Revit 2013
This has always worked correctly in the past. It looks like an un-fixed bug in 2014.
Thanks for replying WWHub.
This is different than what you said back in '09:
"Plan regions don't work well with single story stairs..."
Figured out my solution. The stair in question is an L-shape. An L-shape plan region does not work, even it it is larger than the footprint of the stair. You have to use a rectangular plan region.
What I said in '09 was correct for back then. I had just retested on a multistory stair but I must have crossed the stair and that's why it didn't work. Your plan region has to include the entite stair. L shape stairs work as do rectangular.
Plan Regions Cutting Stairs |
Thu, May 26, 2011 at 6:14:13 PM
Generic model cut plane & plan regions |
Thu, May 20, 2010 at 6:44:23 AM
Plan Region & stairs |
Thu, Jun 18, 2009 at 1:28:37 PM
Plan Regions |
Fri, Jun 17, 2016 at 12:50:12 PM
Stair Cut Lines |
Sun, Nov 6, 2011 at 8:43:09 AM
Members: | 2097976 | Objects: | 23164 | Forum Posts: | 152289 | Job Listings: | 3 |
