139 Users Online (138 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> FILE SIZE AND REPETITIVE ITEMS
Sun, Apr 20, 2014 at 6:52:41 PM | FILE SIZE AND REPETITIVE ITEMS
mongopac
I am working on a project that will have some wall surfaces clad with corrugated metal.
For speed, I just constructed a quick in place model of one corrugation and then arrayed it.  That got me wondering. Is it more efficient for Revit to array a single simple item such as a corrugation, say 80 times, or is it more efficient to design a repetitive single object that models the 80 corrugations in a wall?
Mon, Apr 21, 2014 at 7:25:39 AM | FILE SIZE AND REPETITIVE ITEMS
The most efficient is to NOT model the corrugations.  Use a material!
Mon, Apr 21, 2014 at 10:43:55 AM | FILE SIZE AND REPETITIVE ITEMS
mongopac
That's obvious, and most times I wouldn't, but in this case I need to see the corrugations in perspective views for the client's benefit.
Meanwhile, what is the answer to the question?
Mon, Apr 21, 2014 at 10:52:00 AM | FILE SIZE AND REPETITIVE ITEMS
Unless you are very close, materials work for perspective views.
You don't say if you are using in-place or normal families.  Don't array or copy in-place families because each one becomes a new definition.
I can't emphasize enough that if you model these, you are making a mistake.  This site has good Revit materials for metal siding:
http://www.steelselect.com/content/viewresource.php?id=4289&s=lmenu
CUSTOM TEMPLATE FILE [ 1 2 ]
Wed, Aug 12, 2009 at 4:19:28 PM
21
File size
Fri, Nov 16, 2007 at 2:43:49 PM
File size and performance with multiple instances of 3d families
Wed, May 26, 2010 at 4:10:43 PM
Minimizing the architects model to use as our Central File - what a concept!
Mon, Aug 10, 2009 at 11:06:04 AM
decrease file size
Tue, Nov 16, 2010 at 2:06:44 PM
Page generation time: 1.0579
