114 Users Online (112 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> monolithic tank containment
Sat, Apr 19, 2014 at 3:07:48 AM | monolithic tank containment
joeinck
Greetings,
I am drawing a fuel tank containment structure which will be poured as one structure.
I would like my slab and wall to reflect this.  I have attached a sketch to reference.
basically looking to 'join' the wall to the slab.  As it is shown now, one would think that a cold joint exists and that would be bad.
thanks
j
Mon, Apr 21, 2014 at 3:25:43 PM | monolithic tank containment
So ... do this as an in-place family or use a void to cut the void out of a very thick slab.
....or better yet - use the tool already made for this. - A slab edge - which is really just a sweep.
Containment using LINETYPE
Tue, Jan 20, 2015 at 7:22:18 AM
Oil tank
Wed, Oct 12, 2005 at 6:10:27 PM
how to create water tank tanchion
Fri, Aug 12, 2016 at 4:23:38 AM
Adding Volume Parameter into a family
Fri, Aug 30, 2013 at 11:37:26 AM
WATER TANK CHAMFER
Tue, Jun 25, 2013 at 7:28:03 AM
Page generation time: 0.1948
