109 Users Online (108 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Workflow & Implementation >> Hardware >> Revit 2015 Install Error
Fri, Apr 18, 2014 at 9:03:28 AM | Revit 2015 Install Error
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Maybe one of you guys can give me a hand.  I am having trouble downloading Revit 2015.  I am getting the error the "The system cannot find the file specified". I attached an image of the error.  I uninstalled all of my Autodesk programs to try and reinstall them.  For some reason it is only 2015.  I am currently reinstalling 2014 without any problem.  We did sucessfully install 2015 on other computers so I am at a loss as to what I am missing.
Edited on: Tue, Apr 22, 2014 at 7:52:44 AM
Fri, Apr 25, 2014 at 12:43:05 PM | Revit 2015 Install Error
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Funny I had that trouble with 2014. Took 12+ hrs to download and install after a few failed attempts.
Did you download the file first then install or are you installing directly over the web ? Always better to download first.
My 2015 took about an hour to download then 2.5 hours to install but no errors.
Fri, Apr 25, 2014 at 12:59:18 PM | Revit 2015 Install Error
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
did you download from autodesk.com or subscription center?
I've had customers having issues with the akamai download tool.
There are some different options for the download if you look here:
http://screencast.com/t/yA3UvVHyQML
Fri, Apr 25, 2014 at 1:01:21 PM | Revit 2015 Install Error
alabaster2513
3.5 Stars: 25 Votes
oops you can see my broswer history.... good thing I wasn't looking at anything inappropriate.
Sun, Apr 27, 2014 at 8:03:38 PM | Revit 2015 Install Error
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
For some reason internet explorer wouldnt do it, I had to download Chorme and it worked using the browser download
Tue, May 20, 2014 at 9:24:56 AM | Revit 2015 Install Error
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
In the past I've had to use IE, but now it seems to work with Chrome....finally.
EDIT: I've had this happen to me back in I want to say, 2010 or 2011.  Basically it was the download agent not downloading a *.cab file properly, so when Revit went to install the render material library, it crashed.  Took about 4 attempts but it finally successfully downloaded the .cab file.  I'm wondering if you aren't having the same problem.  When you download, please make sure you have a flawless, un-interrupted internet connection with no static.
Edited on: Tue, May 20, 2014 at 9:28:14 AM
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Revit 2015 ODBC Error
Tue, Nov 11, 2014 at 12:53:42 PM
REVIT 9 INTSTALLATION ISSUES
Fri, Aug 4, 2006 at 10:57:53 AM
REVIT 2015 DELETE FAMILIES FROM FILE BEFORE OPENING IT - UNRECOVERABLE ERROR
Thu, May 12, 2016 at 7:57:16 AM
Fatal error on a shared job Revit 2015
Tue, Mar 15, 2016 at 1:06:33 AM
Revit 2015 Error messages - External Tools - Help?
Wed, Aug 12, 2015 at 12:25:19 PM
Page generation time: 3.9416
