31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cutting a complex Curtain Wall Panel
Wed, Apr 16, 2014 at 10:24:40 AM | Cutting a complex Curtain Wall Panel
Tim79
Hi there,
I would like to be able to cut a complex curtain wall panel using a void. The curtain wall panel is a sort of applied shading facade designed to be applied to the outside of a basic wall. It includes both vertical facade elements and a horizontal shading element above.
I would like to be able to cut the element on an angle in plan so that I can mitre the panels on a corner of a building.
The Void that I have drawn doesn't want to cut anything. Can anyone help?
Please see attached file.
Thanks in advance
Wed, Apr 16, 2014 at 10:42:41 AM | Cutting a complex Curtain Wall Panel
Your process will not work.  If you need to to the cutting in this family rater than the nested families, then create a face based generic faily with a void the cuts the host.  You should make that fully parametric so that you can use it for each elemat you have to cut.  I placed a "screwy" one in your family to show that it works.
I don't know that your family will work in Revit.  Curtain wall panels are tricky so do some early testing.
Thu, Apr 17, 2014 at 9:44:49 AM | Cutting a complex Curtain Wall Panel
Tim79
Thanks for that. Up till now, the panel has been working very well - it's just this question of mitering the corner that is getting a little complicated.
I'm keen to try whatever I can, so would like to see how your void family works - both in the main family and within the individual nested families. Is there any chance you could upload your file?
Again - many thanks.
Cutting a Curtain Panel
Wed, May 14, 2008 at 8:19:29 AM
Curtain Wall Panel to Curtain Wall Door
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
curtain wall panel losses end - edge
Tue, Jul 15, 2014 at 7:04:22 PM
Curtain wall - empty panel issue
Mon, Mar 25, 2013 at 2:34:28 PM
13
Page generation time: 3.2115
