111 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Scope Box in View Schedule
Mon, Feb 27, 2006 at 11:00:25 AM | Scope Box in View Schedule
Mactn113
Is there any way to show the Scope box in a view schedule? Phasing is available, why not extents? Any thoughts are greatly appreciated! -Marc
Tue, Feb 28, 2006 at 4:31:03 AM | RE: Scope Box in View Schedule
eldados
eldados Avatar
4.5 Stars: 8 Votes
just out of intrest: why would you like to show scop box in the schedule?
Integrator
KarelCAD
Tue, Feb 28, 2006 at 8:12:43 AM | RE: Scope Box in View Schedule
Mactn113
I am using scope boxes to break up the building into units. Each scope box has a unit name (Unit A, Unit B, etc.). I would like to use the scope boxes to help me define which unit is being shown in each view. As of now I have another parameter called unit which I have to enter manually. Does anyone have any thoughts?
Tue, Feb 28, 2006 at 12:00:58 PM | RE: Scope Box in View Schedule
arccodex1
3 Stars: 1 Votes
You can go to Settings... Project Parameters and add a parameter called "Unit" to doors, windows, rooms, and anything else you want to schedule. Then you go into each schedule and add the Unit field. While in the schedule you can enter the unit names into each door, window, and room. Now you can sort or filter the schedules by Unit. Post edited on 2006-02-28 12:03:10
Make Scope Box Visible after all Views Hidden
Tue, Oct 25, 2016 at 4:40:47 PM
Grid Bubbles relative to scope box.
Tue, Jul 10, 2007 at 4:20:51 PM
Scope Box Datum Control
Fri, Apr 21, 2006 at 6:57:16 PM
Scope box not visible
Thu, Oct 19, 2017 at 12:33:05 PM
scope boxes / far clip offset / view range
Wed, Nov 6, 2019 at 2:11:06 AM
Page generation time: 1.5509
