50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Freezing edited dimensions in a revit family
Mon, Apr 14, 2014 at 8:15:25 PM | Freezing edited dimensions in a revit family
Tallguy88
I am using Revit 2014 and I have downloaded a revit family for a 3d wall mounted sink with counter top.  The counter top is like 6 feet long and I only want it to be 3 feet long.  So I opened the family editor and changed it to what I wanted, locked the dimensions and even unchecked the Instance Paramter box, but despite all that when I save it and load it back into my project and choose to place that component the component still starts out with the 6 foot counter.
How do I edit the family so that the sink countertop will automatically be 3 feet when I place it in my project?
Tue, Apr 15, 2014 at 6:59:10 AM | Freezing edited dimensions in a revit family
3.5 Stars: 395 Votes
Your 25" deep is set to 3' but your 21" deep is set to 6'.  So you used the 21" type - right?
Please note that once a family is loaded, the parameters hold unless you over-write the variables too when asked.
Tue, Apr 15, 2014 at 3:50:30 PM | Freezing edited dimensions in a revit family
Tallguy88
Thank you for the help.  After I edited the family and loaded it into my project I did not select to overwrite with parameters, that was my problem.  And today when I tried reloading it, I was not given that overwrite dialogue box again.  I don't know if that was supposed to be that way or not.  Anyway, I realized I was being dumb and could just edit the parameters in the edit type box.
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:56 AM
Show Family Dimensions in a Project
Mon, Dec 8, 2008 at 9:03:14 AM
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Revit 2014 - Need to eliminate zero feet in dimensions
Thu, Apr 3, 2014 at 1:07:01 PM
Edited Families - Appear different in different views
Mon, Oct 21, 2013 at 7:55:41 AM
Page generation time: 5.8058
