48 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> creating subfolders that have each view with different information
8 Posts No Rating |
Hi,
I am able to create sub folders and locate a certain view to this folder, however, i want to have folders for different stages of a project such as planning drawings, fire cert drawings, construction drawings, etc. as each of these stages would require a different amount of information on the drawings, ie planning drawings would not require fire safety regulations, etc. BUT, when i duplicate the ground floor plan for instance from the planning drawings sub folder, and relocate the copied view to fire safety certificate, and rename, when i make changes to that plan it also changes in the planning drawings view. i copied without detail.
do i have to hide everything that is not needed in each view. i thought when creating a new view in a new subfolder the information that is put on this view would just be for this view, but for some reason i can not figure out and i hope i have explained myself the best i could here.
What year ??? Always post.
This sounds like 2013,14 and you have a view template?
Or did you not copy with detailing but instead used copy dependent?
Only guessing because you gave so little information. What did you change? Model elements? If so well then yea... model is model and is the same in all views unless you use design options.
Subfolders in the Project Browse? |
Mon, Feb 22, 2010 at 6:39:05 PM
Settings - Project Information help |
Sun, Apr 17, 2005 at 10:24:54 PM
Importing sheet view with 3d information into separate model |
Fri, Jun 22, 2012 at 2:25:05 PM
Creating Families |
Fri, Sep 15, 2006 at 2:24:07 PM
Creating an Enlarged Detail View of a Detail I have Drawn |
Fri, Aug 31, 2012 at 7:05:29 AM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
