61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2014 Selection Window
Thu, Apr 10, 2014 at 3:16:55 PM | Revit 2014 Selection Window
HermanMunster
I have read through the posts but did not find one specific to this unless I missed it. I am editing a garage door family and for some reason I cannot window select the elements that I want to mass edit. The elements are lines so I cannot select all in view. Not that I would want to as I am creating interior panels.
The wall the garage door is on keeps getting selected when I window not the interior panel lines
Any ideas or direction would be helpful
Thu, Apr 10, 2014 at 3:27:52 PM | Revit 2014 Selection Window
When you say mass edit, you mean just to change their type?  ...or move ooo or copy them all at once.  That's about all you can do.
2D lines I assume.  You can widow that area in the appropriate view then look at your filter and remove the items you don't want from the selection set.  You can only select 2D lines that are normal to your view.  (Like - elevation lines will not be in a plan view)
Edited on: Thu, Apr 10, 2014 at 3:28:26 PM
Thu, Apr 10, 2014 at 3:37:53 PM | Revit 2014 Selection Window
HermanMunster
Thank you wwhub. I have 2d lines to represent panels within the door. I have created one set and I wanted to highlight the entire panel to multiple copy.
When I try to window the panel it selects the extrusion behind. If I pin the extrusion it still selects. I have attached the south elevation
Thu, Apr 10, 2014 at 4:03:32 PM | Revit 2014 Selection Window
You can't edit the family in the project.
Thu, Apr 10, 2014 at 4:10:25 PM | Revit 2014 Selection Window
HermanMunster
Sorry I wasn't clear on the attachment. The elevation was only for reference for the garage door family inserted into my model.
I am editing the door sweeps and extrusions within the family not the model.
Within the family it won't let me window.
Fri, Apr 11, 2014 at 7:49:25 AM | Revit 2014 Selection Window
It is probably not a full revit family but possibly CAD or sketchup.
select elements on current level only - revit 2014
Tue, Jul 23, 2013 at 7:52:34 AM
polyline selection window
Sat, Feb 6, 2016 at 7:57:08 AM
selection window grabs wrong items
Thu, Jul 19, 2012 at 3:05:38 PM
Stumped on why window selection or crossing selection wont pick pipe fittings ?
Sat, Jun 1, 2024 at 1:44:17 PM
Revit 2014 Error: Property Window and Project Browser Window
Mon, Apr 14, 2014 at 5:52:53 PM
Page generation time: 3.6071
