Forums >> General Discussion >> Revit Project Management >> Shared parameter for Wall finishes
Is it possible to create a shared parameter that allows to tag the external layer of a wall?
Thanks
You can use a material tag. That demands that you keep you material descriptions up to date to what you want.
We edit the material description so that it is all caps. Also for items like stud wall cavities, we may have multiples like 3 1/2" metal stud @ 16" oc with 3 1/2" batt insulation then anothe one that doesn't have the batt... etc. We have seperate materials for 4", 6", 8", 10", 12" CMU .... understand?
^^ By doing this, we can material tag our wall type legends and know that everything is correct in the project.
Edited on: Thu, Apr 10, 2014 at 10:40:22 AM
Thanks WWHub
Is it possible to use that information given to the walls/materials with Room Tags?
Sorry - walls don't associate with rooms. Afterall ... they can face more then one direction and span multiple rooms.
wall finishes by room |
Tue, Apr 19, 2005 at 11:40:25 AM
Cannot Locate SHARED PARAMETER FILE! |
Tue, Oct 7, 2008 at 3:16:48 PM
Shared Material Between Families |
Mon, Aug 31, 2015 at 11:21:40 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Instance Shared Parameter?? |
Fri, Jul 11, 2014 at 2:49:26 PM
Members: | 2104043 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
