72 Users Online (71 Members):
Forums >> Revit Building >> Tips & Tricks >> LEVEL Parameter in Material Takeoff
0 Posts No Rating |
I would like to ask for assistance on how to create new parameter in material takeoff. I want to add "level" parameter in order to count the quantity of block walls per level.
Hoping to hear from those revit expert soon. Thank you!
Are you walls seperated by level? If so, you have some options but in many cases wall span more then one level and there are obviously no options there.
0 Posts No Rating |
The Block walls are separated per level. I cannot find the right option when creating new parameter for level since it is not included in the selections. What selection should I use in the following when adding new parameter:
1. Type of Parameter
2. Group Parameter Under
Thanks!
You can add a project parameter to walls that you fill in.... your parameter, nothing automatic.
Material Takeoff |
Mon, Apr 27, 2015 at 7:32:15 AM
Ceiling Material Takeoff |
Thu, Feb 15, 2007 at 3:19:57 PM
Material Takeoff issue |
Mon, Oct 25, 2010 at 3:48:35 PM
Material Takeoff for insulation?? |
Mon, Oct 28, 2013 at 9:57:10 AM
Sheathing Material Takeoff |
Mon, Apr 25, 2011 at 7:01:06 AM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
