69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Randomized Colors Tile Pattern
Wed, Apr 9, 2014 at 2:36:44 AM | Randomized Colors Tile Pattern
OwnageHawk
Hello,
I have an exterior area paved with 20 x 20 cm tiles.  The client wants 70% of the tiles to be 1 color with the other 30% being another color organized in a "random" fashion.
Is there a way to do this in Revit?  Right now I have my floor material with a 'paint' applied on it to create the 20 x 20 pattern.
Any suggestions would be greatly appreciated.
Wed, Apr 9, 2014 at 7:13:23 AM | Randomized Colors Tile Pattern
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Depending on how big the area is you may want to just paint the areas you need a different color.   I also came across this post but I have not tried it and I'm not sure if it would be applicable to your situation
http://dp-stuff.org/randomizer-revit-addin/
Wed, Apr 9, 2014 at 9:46:05 AM | Randomized Colors Tile Pattern
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Do it manually, with a custom material:
With a pattern created with mertens (or wich you prefer) create a pattern with obscured and clear tiles
in the porcentage the client wants (70/30).Thats for documentation
Then paint it in photoshop or gimp repaint the obscure ones, and save the texture as a JPG or PNG. Link it to the tiling
material and set the correct size.This is for rendering and shaded looking.
If you have any doubts, search for "material creation revit"
Tue, Jul 8, 2014 at 1:20:02 AM | Randomized Colors Tile Pattern
Thread Post Kudo! #4
online2000
online2000 Avatar
in case you are trying to colour a tiled/paved area with random colour(tones) that mac a certain spectrum...
REVIT CAN DO IT FOR YOU AUTOMATICALLY!!
dont use any other method
when editing your material-CREATE A TILES 'COLUR'
 note that when creting tiled texture, under the Texture editor you can randomise the tone factor- thus creating variations of tones between the tiled surface\see images for explaination
eli
Make realistic tile pattern
Fri, Jun 25, 2010 at 9:43:53 AM
Tile Pattern Height
Mon, Oct 9, 2006 at 2:36:02 PM
Offset tile pattern
Wed, Jan 1, 2014 at 5:56:13 PM
Custom Offset tile pattern with four sizes
Mon, Aug 8, 2011 at 11:48:10 AM
Tile Pattern
Sat, Mar 24, 2012 at 7:10:38 AM
Page generation time: 0.6679
