58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> In place sweep- change of level?
Tue, Apr 8, 2014 at 4:09:51 AM | In place sweep- change of level?
seburne
Hi, i've created an in place sweep through components- generic models, in revit 2014. I've managed to get it to curve, but I need it to drop down in level from the start point to the end point.
Is this possible with an in place sweep? If so, how is it done? Reference planes?
Thanks in advance for your help
Tue, Apr 8, 2014 at 7:33:58 AM | In place sweep- change of level?
The sweep path has to be defined in 3 dimensions.  If it all can lie on one work plane set at an angle, then create that plane and a view normal to it and sketch your path.  If the sweep path does not all lie on one plane, you can create 3D lines that join at the ends or some sort of mass with an edge and use pick path.
You might also be able to create it in a normal plan and rotate it in elevation if it all lies on one plane.
Edited on: Tue, Apr 8, 2014 at 7:34:54 AM
Level height change
Wed, Sep 28, 2011 at 2:10:59 PM
Wall Sweep Grips
Mon, Sep 13, 2010 at 4:49:28 PM
3D in place sweep problem, changes angle
Mon, Jan 28, 2008 at 12:56:38 PM
Wierd Hatch Orientation on In-Place Wall Sweep
Fri, Nov 4, 2005 at 3:37:18 PM
Profile uploading for model in-place component sweep
Sun, Oct 21, 2012 at 6:28:15 AM
Page generation time: 2.3002
