46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> the load in family not working
Fri, Apr 4, 2014 at 10:24:20 AM | the load in family not working
lwulf353
1 Stars: 3 Votes
Every time i try to load in somthing for the files or load in something from revit city it never show up and i was wondering what im doing wrong or how to fix it?
Fri, Apr 4, 2014 at 10:40:12 AM | the load in family not working
You don't load from Revitcity directly into a project.  You download to your system then you load it into the project using the Revit load process.
Mon, Apr 7, 2014 at 10:45:21 AM | the load in family not working
lwulf353
1 Stars: 3 Votes
i have downloaded it and had it open but when I press the load into project button it never show up in the project. That what i need help with.
Mon, Apr 7, 2014 at 10:49:56 AM | the load in family not working
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Look in your Project Browser under Families and find it.  You may be trying to bring it into your project the wrong way
Tue, Apr 8, 2014 at 10:42:21 AM | the load in family not working
lwulf353
1 Stars: 3 Votes
I found the faimlly and when i click load into project it close out of the faimilly and goes to my projuct but it never showes up. the second picture is what it look like after I click the load in to project when the object doesnt show.
Tue, Apr 8, 2014 at 10:46:21 AM | the load in family not working
Well did you actually place it????   Revit can't guess as to where you want it.  This is a curtainwall door and you have to swap out a curtainwall panel with this.
Please - please - read your HELP - Curtain walls.
Tue, Apr 8, 2014 at 10:52:15 AM | the load in family not working
lwulf353
1 Stars: 3 Votes
I would place it if it would show up for me to place. i have loaded in thing before with no problem.
Tue, Apr 8, 2014 at 10:56:40 AM | the load in family not working
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need read our responses better.  You need to click on the curtain wall panel that you want to change and in the type selector pulldown change it from the Glazing to your Door
This is a process problem not a Revit problem.  As WWHub said you should read up in your help on curtain walls and learn how they work so that you know how to change the panels, mullions etc.
Edited on: Tue, Apr 8, 2014 at 10:57:50 AM
Tue, Apr 8, 2014 at 11:01:10 AM | the load in family not working
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Ahh, the chicken or the egg.
Here is the answer:
If the door you are looking to place is part of a curtain wall family, then you most likely have loaded it in the project.  However, those types of doors will not show up right away.  Here is what you have to do:  Click on the curtain wall glass panel where you want the door to be, unpin it and then swap it using the type properties menu pulldown.  Your new door should appear in that pulldown menu.
It is that easy.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Wed, Apr 9, 2014 at 10:41:11 AM | the load in family not working
lwulf353
1 Stars: 3 Votes
Thanks that work
Fri, Aug 19, 2016 at 1:01:12 AM | the load in family not working
melonyo
!!!!!!!!!!!! HERE IS WHAT I FOUND AND IT WORKS VERY WELL !!!!!! ATTENTION !!!!!
1) DOWNLOAD THE FAMILY OR WHATEVER U WHAT
2)OPEN IT USING REVIT
3)CLICK LOAD INTO PROJECT
4)GO TO YOUR PROJECT THAT U WANT TO LOAD THE DOWNLOAD CONTENT
5)GO TO ARCHITECTURE TAB > COMPONENT > PLACE A COMPONENT
6) THATS IT !!! LOVE ME ~~~
Load Family button does not pull open the file browser
Wed, May 4, 2011 at 1:55:38 PM
Window will not load into a wall in a project - working in it's own family tho..
Mon, Jan 24, 2011 at 9:49:53 PM
Load Family in Project causes Revit to Crash!
Mon, Oct 26, 2009 at 7:02:59 AM
Cannot load family
Mon, Apr 18, 2011 at 5:22:02 PM
Void Etrusion not working when I load family
Tue, Apr 28, 2009 at 2:27:58 PM
Page generation time: 1.6856
