60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2014 - Need to eliminate zero feet in dimensions
Thu, Apr 3, 2014 at 11:10:19 AM | Need to eliminate zero feet in dimensions - Revit 2014
Prophecy99
Prophecy99 Avatar
I tried searching but didn't find anything to clear to my question.  I have some dimensions that measure (0'-0 1/2")  I want them to read (1/2")  how do I eliminate the zero feet and hopefully the zero inches?
Thanks for any help, this should be really easy, not sure what I am missing. I checked project settings, and the dimension style family but can't find any check boxes etc. or settings that apply to what I need.  Could it be a unit issue?
Edited on: Thu, Apr 3, 2014 at 11:18:51 AM
Imagination reveals truths reality obscures.
Thu, Apr 3, 2014 at 12:25:33 PM | Revit 2014 - Need to eliminate zero feet in dimensions
It is in your unit setup.
Thu, Apr 3, 2014 at 12:32:28 PM | Revit 2014 - Need to eliminate zero feet in dimensions
jkirk88
Manage>Project Units then you check off suppress 0. Always works for me.
Thu, Apr 3, 2014 at 12:48:08 PM | Revit 2014 - Need to eliminate zero feet in dimensions
jkirk88,
Be careful.... Poject units might do the job but probably not.  Most of our annotations and dimensions don't use project unit but have their own settings.  We prefer project units to be to 1/256" for quality of the model but our dimensions don't use that setting for obvious reasons.
Thu, Apr 3, 2014 at 12:53:09 PM | Revit 2014 - Need to eliminate zero feet in dimensions
Prophecy99
Prophecy99 Avatar
Thanks a lot WWHUB for the prompt reply . That was it. I wasn't sure if I should defere away from "project" settings but your explaination makes sense. Accurate model to the 1/256" and then change the settings of the dims themselves.
thanks!
Thu, Apr 3, 2014 at 1:04:03 PM | Revit 2014 - Need to eliminate zero feet in dimensions
jkirk88
WWHub,
You're correct but I read this post as a visual problem, nothing more. Also your screen capture is the exact menu that pulls up when I click project units.
Edited on: Thu, Apr 3, 2014 at 1:07:59 PM
Thu, Apr 3, 2014 at 1:07:02 PM | Revit 2014 - Need to eliminate zero feet in dimensions
jkirk88
WWHub,
You're correct but I read this post as an visual problem, nothing more. Also your screen capture is the exact menu that pulls up when I click project units.
Dimensions in feet and meters
Tue, Jan 18, 2011 at 7:45:32 AM
Freezing edited dimensions in a revit family
Tue, Apr 15, 2014 at 3:50:31 PM
Level Display (only) to decimal feet
Sun, Aug 10, 2014 at 11:00:02 PM
12
eliminate cut profile in section view
Tue, Aug 12, 2008 at 12:23:28 PM
Rendering toposurface under 0 feet
Thu, Apr 6, 2006 at 2:19:21 PM
Page generation time: 2.1375
