70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Cut a sloped beam
Sun, Feb 26, 2006 at 3:53:58 PM | Cut a sloped beam
RevitRenzo
3.5 Stars: 3 Votes
Is it possible to cut a sloped beam in Revit 8.1. I have tried to add a void into the beam family to the end of the beam? But that is not working, because my beam has a slight slope. Do you have any ideas See also the attached detail (in elevation). The cyan column is vertically oriented. The beam (green) has a slight slope and the plate (yellow) has to be vertically attached to the column.
Thu, May 10, 2012 at 2:24:27 PM | Cut a sloped beam
scochrancpslo
Any solutions?  I have a regularly sloped beam system that ends in a series of walls that are curved in plan so that the beams are not perpendicular to the wall in plan or elevation.  I would love to just void the ends of the beams off at the wall...
Fri, May 11, 2012 at 3:48:20 AM | Cut a sloped beam
4 Stars: 202 Votes
I don't know if this solve your problem because we don't have any image to check, but... go to an elevation or section view, create a Ref. plane  in the place where you want to cut, now use the "Cut geometry" tool, select the ref. plane and your beam.
Sloped Beam?
Thu, Dec 15, 2005 at 3:38:37 PM
Need Help on Sloped Beam-Column Connection
Fri, Apr 29, 2016 at 1:50:44 PM
Sloped Beam Connection
Thu, Feb 21, 2013 at 11:13:16 AM
Copy array of cut beam
Tue, Mar 7, 2017 at 1:08:33 PM
Attaching open web trusses to a sloped beam
Wed, Jun 20, 2012 at 5:15:08 PM
Page generation time: 1.1513
