87 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> "XREF" Families or other possibilities?
Thu, Apr 3, 2014 at 10:14:32 AM | "XREF" Families or other possibilities?
pleojera
pleojera Avatar
Hi,I am working on a project with lots of buildings. And it is impossible to work in one revit file. Anyway, the problem is; when i change a family or the customer asks a revision for a family in project, it is really tiring job to open and load every changed family to every building. Is there any way to work with families like "Xref" in Autocad? So thus, when i change a family; automatically it will load it the buildings i attached that family file before. Or something like that. Smile I am open any other suggesstions except that "open all buildings together, check them on popup and load it once." Smile
Thu, Apr 3, 2014 at 10:33:02 AM | "XREF" Families or other possibilities?
The only possibility is to create some sort of script to do this because the file has to be opened and the family loaded.  Maybe someone has something elsewhere but I have not seen anything here.
Fri, Apr 4, 2014 at 1:47:42 AM | "XREF" Families or other possibilities?
pleojera
pleojera Avatar
Thank you. I wasn't so hopeful anyway.
"Xref" in Revit
Sun, Mar 24, 2019 at 7:52:44 AM
file getting too big, is there "xref" or something similar?
Fri, Apr 18, 2008 at 12:19:42 AM
Can the room schedule have a column that automatically fills in ceiling height?
Fri, Jul 13, 2007 at 11:53:53 AM
How do you change a "generic model" family into a "mechanical equipment" family?
Fri, Apr 6, 2018 at 6:18:20 PM
"ADA Clearances" in families
Tue, Sep 11, 2012 at 10:34:17 AM
Page generation time: 2.2471
