78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> 3D pdf converter for Revit LT?
Thu, Apr 3, 2014 at 6:10:56 AM | 3D pdf converter for Revit LT?
TimGarry
Does anyone know if one exists as I cant establish wehther the most available actually work with Revit LT, the trials dont seem too but then other full version holders have the sam eproblems so without forking out the expense I wondered if anyone knew of one that did in fact work?
many thanks
Tim
Thu, Apr 3, 2014 at 7:03:58 AM | 3D pdf converter for Revit LT?
PDF's are a print process, not a conversion.  They are not provided with Revit, you need a 3D PDF program.  Instead, you can create 3D DWF's, that is supported.
Thu, Apr 3, 2014 at 6:43:44 PM | 3D pdf converter for Revit LT?
TimGarry
I have been told by 3DA systems that there process is not compatible with LT, just wondered if anyone knew of any that were?
Try the 3D PDF Converter Plug-in for Autodesk® Revit today and get it for free
Thu, Feb 16, 2012 at 10:40:14 PM
PDF - DWG, DWG - PDF
Mon, Jan 26, 2015 at 11:15:57 PM
REVIT 2012 BATCH CONVERTER
Thu, Jun 30, 2011 at 4:27:11 PM
Announcing the 3D PDF Converter for Revit Pre-Release Program
Wed, Dec 7, 2011 at 3:14:27 PM
Current 3d PDF converters?
Tue, Mar 13, 2018 at 4:33:22 PM
Page generation time: 1.6188
