Forums >> General Discussion >> Revit Project Management >> Translucent polycarbonate facade
hi all! I'm new to revit and am a freshman in arch school. i'd like to make a facade like this (http://construction.com/CE/CE_images/2012/Aug_Extech_7.jpg) after research i know this is called "polycarbonate",
i want to use this as my facade, so that light can emits through the translucent wall and looking cool at night, how can i make it? i know how to import an image as a new material and adjust those translucent thing but i just can't make it, anyone got this kind of material photo and experience in designing such facade?
thanks a lot! 11 days to my final review......!!
This is just a curtainwall with translucent panels instead of glass. Read about curtainwalls in your HELP.
You will just make a material and add Self Illimination to it in the Material Browser>"Your Material">Appearance>Self Illumination... if you want it to be a little transparent you can also set that in the same location.
thanks for the reply, but how can i make a curtain wall *translucent* but not completely transparent?
by the way i have tried loads of the material photos online and none of them work.....
how to add those vertical lines onto the curtain wall??
sorry for asking so many questions! i really want a translucent facade as the photo shows....
In the material of the curtail wall panel you can set the transparency. Those vertical lines are girts.. most likely a C Channel that you would place as a beam in Revit.
Water mark not translucent |
Mon, Jul 20, 2015 at 1:01:45 AM
Casting shadows with translucent objects? |
Wed, Sep 2, 2009 at 3:51:38 PM
Translucent Existing Phase after Rendering |
Sun, Sep 28, 2014 at 7:08:35 AM
Translucent Filled Regions |
Tue, Dec 13, 2011 at 7:34:32 AM
metal facade? |
Wed, Dec 21, 2005 at 9:37:11 AM
Members: | 2098637 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
