Forums >> Revit Building >> Technical Support >> Lighting Fixtures show black in rendering but light in different angles
Mon, Mar 31, 2014 at 12:36:35 AM | Lighting Fixtures show black in rendering but light in different angles
Andy100101
Hi, Forum Friends,
Please see the attached image: Lighting Problem: Troffer Light - Lens 2'x2'(2 Lamp) - 120V is from the Revit Architecture 2013 family. the 2 lights on the right side show black in rendering. But as shown in attached image: Lighting Problem 2, if I rotate the angle and zoom in, they have no problem. I tried everything I could think about and browsed many online topics, and I set the rendering quality to High, but I just do not have a clue.
Please Help! Thanks so much in advance!
Mon, Mar 31, 2014 at 4:08:22 AM | Lighting Fixtures show black in rendering but light in different angles
4 Stars: 201 Votes
Similar thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=23814
Edited on: Mon, Mar 31, 2014 at 4:08:55 AM
Mon, Mar 31, 2014 at 9:46:46 AM | Lighting Fixtures show black in rendering but light in different angles
Andy100101
Typhoon, Thanks for helping. I tried everything introduced in the threads you forward to me. but still not work.
i checked self-illumination, set glossiness to 50, and when i tried to set invensity to a higher value, the drawing burnt while lights remain dark. The light and the ceiling all from revit its own family.
Mon, Mar 31, 2014 at 4:41:06 PM | Lighting Fixtures show black in rendering but light in different angles
Andy100101
Hi, Everybody,
Again, I did the following as my current settings:
1. Use the family inside the softweare not from downloading, both ceiling and lighting fixture
2. Check "Emit Shape Visible in Rendering"
3. Diffuser Material: Check "Reflectivity", Set "Transparency 95", Check "Self-Illumination"
But I also tried other settings and different setting combinations. I even ever pulled the light out side the ceiling.  And if I did something wrong, why other lights are ok.
No matter how, the three miserable ones simple not light up.
Please Help!
THANKS!!
Wed, Apr 2, 2014 at 10:44:11 AM | Lighting Fixtures show black in rendering but light in different angles
Andy100101
Seems my question is very hard, becasue like i said above i used revit inner family resouce and tried multiple things i could find online, and only some lights do not work. Hi, are there any revit software writers out there? Please help. Thanks!
Wed, Apr 2, 2014 at 10:56:53 AM | Lighting Fixtures show black in rendering but light in different angles
3.5 Stars: 395 Votes
We really can't help because you don't give us enough information.  If you look at your first posted view, what am I looking at here ? - see my markup.
I don't believe you have lights - it looks like you have holes in your ceiling and I'm looking at the white sky and walls or building beyond.
Who owns the ceiling?
Do your lights cut the ceiling? .... Sure don't match the grid - do they?
Do your lights really work?  We don't have a clue.
Mon, Jun 2, 2014 at 3:44:22 PM | Lighting Fixtures show black in rendering but light in different angles
Andy100101
Hi, WWHub,
Thanks for reply. You marked "What is this?" "And this" in red in the picture. Those are exactly what I am asking for helps.
I used the revit its own ceiling family, lighting family, (not from downloading), Set up all lights the same way, but except these three showing black out areas, the others are looking good.
Tue, Jun 3, 2014 at 7:55:10 AM | Lighting Fixtures show black in rendering but light in different angles
These three lights are all the same .... so what's up?
The light on the left has been hidden in view so all we have left is the hole.
The lighting fixtures wont show up in my final revit 2013 rendering.
Wed, Jul 31, 2013 at 3:23:18 AM
Lighting Units not Rendering
Mon, Nov 9, 2015 at 7:03:00 PM
14
How to show lighting fixtures on floor plan
Mon, Nov 6, 2006 at 10:15:38 PM
Tagging Lighting Fixture Symbols in RCP
Fri, Dec 18, 2009 at 1:03:01 PM
lighting fixtures
Fri, Jul 26, 2013 at 9:45:43 AM
Page generation time: 1.7772
