59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Draw wall alignment
Sat, Mar 29, 2014 at 7:05:49 AM | Draw wall alignment
gaudiman
Hello, I am drawing walls with the location line being exterior core face. The problem is I want the walls to snap to the core face when I am drawing new walls to join them, it currently only lets me snap to the center of the wall or the exterior. The whole point of this is to create an efficient wood frame for a house,
Mon, Mar 31, 2014 at 8:20:49 AM | Draw wall alignment
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm not having any problems snapping to the different layers of a wall.  What version of Revit are you using, do you have all of the updates installed?
Mon, Mar 31, 2014 at 11:22:33 AM | Draw wall alignment
gaudiman
Revit 2014, I did realize that my detail level wasn't set to medium or fine, changing that allowed me to draw from different parts of the wall. I still have one issue with this problem. I have an 45 degree angled corner on the first floor. Because I am doing an efficient frame I need to model the first floor before the foundation walls. When I go to make the foundation walls using the first floor as an underlay I cannot snap to the intersection where the two exterior cores meet  on the first floor, though I can snap to the exterior core boundries on 90 degree angle corners.
Mon, Mar 31, 2014 at 12:38:30 PM | Draw wall alignment
You don't need to snap to the intersection.  Align to the proper faces.
curbed wall texture alignment
Sat, Dec 1, 2012 at 5:47:58 AM
Beam alignment problem
Wed, Mar 13, 2013 at 3:35:35 AM
Wall alignment
Fri, Oct 26, 2007 at 1:40:55 PM
wall alignment
Tue, Jan 11, 2011 at 6:00:11 PM
Outlet & light switch alignment
Fri, May 15, 2009 at 6:54:47 PM
Page generation time: 1.4875
