59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> hatch pattern
Fri, Mar 28, 2014 at 1:45:02 PM | hatch pattern
swdebenport
5 Stars: 3 Votes
I have been looking around and still have not found an answer to the issue of line weights in hatch patterns.  Revit 2014 seems to havesome default that sets cut at projection patten line weights differently  (see image).  The top part of the image is in cut the bottom in projection.  Is there any way I can make them both look like the top?
also kind of a strange side note... If i change the material of the wall from concrete to a default wall both line weights are thick.
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:36 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:52 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:48 AM
Hatch 22- Curve Pattern
Wed, May 30, 2018 at 4:07:08 PM
custom hatch pattern without hatch editor
Wed, Jan 28, 2015 at 8:46:59 PM
Page generation time: 0.2994
