71 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> what is the easy to do toposurface
Sat, Feb 25, 2006 at 7:16:41 PM | what is the easy to do toposurface
why8888
i got the survey plan from surveyor, i do not know how to use the toposurface? onho
Sat, Feb 25, 2006 at 8:20:33 PM | RE: what is the easy to do toposurface
razorback
Open up your site plan view then file import your topo dwg file, check the current view only. On the site design tab click toposurface then click use imported>>Import Instance then pick your imported dwg on screen then on the pop up dialog box you can just click ok then lastly click finish surface. Hope this helps....
Sun, Feb 26, 2006 at 11:02:29 AM | RE: what is the easy to do toposurface
Rookwood
Make certian that the drawing you received from the surveyor has the Z coordinates for the contours. Not always included. You can go into the drawing and maually set them, if necessary. Also, often the civil or surveyor's drawing will be in decimal units and your drawing will be in architectural units. I usually will take the surveyor's drawing and save it as a different name. Then I will change the units from decimal to architectural and then scale the drawing a 12 times for the unit conversion. Import as razorback describes and then majic happens. I still haven't gotten the 'Relocate Project' trick as yet. When you import topo, it will come in at actual grade levels while your project is usually set at 0' elevation. Relocating the project relocates the topo also, so you keep chasing the grades.
Sun, Feb 26, 2006 at 5:24:34 PM | RE: what is the easy to do toposurface
why8888
it is help a little, but my topo does not look right... The highest point RL 50.00 should happen at the left hand side, and the lowest point is right hand side. the result is totally wrong. onho
Sun, Feb 26, 2006 at 5:27:27 PM | RE: what is the easy to do toposurface
Rookwood
why8888, Can you post your original .dwg file from the surveyor?
Sun, Feb 26, 2006 at 5:53:21 PM | RE: what is the easy to do toposurface
why8888
Here is the original copy of dwg. file onho
Sun, Feb 26, 2006 at 6:16:10 PM | RE: what is the easy to do toposurface
Rookwood
Did you forget to attach the .dwg file? Notice there is a 2Mb limit on the file size.
Sun, Feb 26, 2006 at 6:18:26 PM | RE: what is the easy to do toposurface
why8888
i am sorry that file it over 2mb. i can't attach onho
Sun, Feb 26, 2006 at 6:48:06 PM | RE: what is the easy to do toposurface
Rookwood
why8888, Try saving the file as a different name, delete all the extraneous layers except the contour data, purge the file then saveas again with the same file name. If necessary, zip the file and see if this reduces the file size. Saveas again removes all the historical data since the renaming.
Sun, Feb 26, 2006 at 7:16:17 PM | RE: what is the easy to do toposurface
why8888
here you are
Sun, Feb 26, 2006 at 8:21:14 PM | RE: what is the easy to do toposurface
#11
Rookwood
why8888, Your dwg file worked okay for me. The file you attached had no values for any of the Z coordinates, so I merely added the value you had as contour notes. I then copied the contours without text onto a clean and blank dwg file, changed the units to architectural and scaled the contours at 12X. There was some sort o white box to the right of your drawing that I couldn't get close to. It would disappear when I zoomed in and would move. I toggled the frames, thinking it may be an inserted image.
Sun, Feb 26, 2006 at 8:27:59 PM | RE: what is the easy to do toposurface
#12
Rookwood
why8888, Here is a larger version. I couldn't preview the previous attachment.
Sun, Feb 26, 2006 at 10:52:04 PM | RE: what is the easy to do toposurface
#13
why8888
thanks i will try it now. onho
Sun, Feb 26, 2006 at 11:35:31 PM | RE: what is the easy to do toposurface
#14
why8888
i don't understand how you place the z-coordinate onho
Mon, Feb 27, 2006 at 8:44:07 AM | RE: what is the easy to do toposurface
#15
Rookwood
Open your surveyor's drawing in AutoCAD. Select a contour line and open the properties dialog box. Depending on the way you are setup, the 2nd section down should be GEOMETRY. About 3/4 down there will be a line named ELEVATION. There, to the right, you will be able to enter the elevation value of the contour line you selected. Do this for each of your contour lines. Your drawing may have this information entered already. I notice that often when I copy, paste, scale, etc. that the contour lines will lose these values and they need to be entered manually. Also, you may NOT have the option of ELEVATION, but will see X Y and Z coordinates where the Z coordinate is the value of the elevation. Simply enter your information there. Someone else may have a simpler method.
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface-Extra lines that shouldn't be there. Image included
Sun, Feb 20, 2011 at 10:49:51 PM
Toposurface in Elevations
Thu, Aug 27, 2009 at 1:51:06 AM
Toposurface
Tue, May 11, 2010 at 9:04:45 AM
Page generation time: 0.6379
