124 Users Online (123 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Room schedule input when working from an Architectural linked file
Wed, Mar 26, 2014 at 3:20:30 PM | Room schedule input when working from an Architectural linked file
TJNG1
I am a commerical interior designer still learning the best way to incorporate Revit into interior design.  currently working a project with an architectural model linked-in.  I can generate a room schedule based on the model but can not input the necessary room info.  Does anyone have suggestions on the best way to complete this task?  copying the rooms is not an option as it results in double counting on the archtects end.  Thank you for any input.
Wed, Mar 26, 2014 at 3:33:11 PM | Room schedule input when working from an Architectural linked file
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If you are trying to pull information from a linked model that information needs to be in the linked model first, you can't add it from your project.
Wed, Mar 26, 2014 at 3:38:18 PM | Room schedule input when working from an Architectural linked file
TJNG1
That is what i thought.  Hope for a better solution.  Thinking of trying space tags in my model.
Room Schedule - How to not schedule linked file rooms
Tue, Feb 16, 2010 at 6:13:59 PM
Room Schedules in Linked File
Mon, Apr 20, 2009 at 11:23:55 AM
Scheduling from linked Revit file
Tue, Mar 27, 2012 at 7:39:28 AM
How to make room tags in a linked file visable?
Thu, Jul 30, 2015 at 1:12:22 AM
Furniture in Host Model not recognizing Linked File Room Bounding
Fri, Oct 4, 2013 at 7:02:23 AM
Page generation time: 1.3873
