Forums >> Revit Building >> Technical Support >> Shadows on Glass in Exterior Elevations
2 Posts No Rating |
This may be a redundant question, but is there a way to alter shadow settings so that in an exterior elevation, glazing does not recieve shadows?
As with some schools of hand rendering, I prefer to no cast shadows onto glass when drawing an exterior elevation. Is there a way to do that in Revit, or do I have to alter the elevations after the fact in another program like PS?
2 Posts No Rating |
Oops, sorry. Forgot to say that I'm using Revit 2014.
Why not turn off the glass or make it transparent?
2 Posts No Rating |
Thanks for the suggestions. The glass material is already set to transparent, and if I hide the glass, it makes the opening even darker. Having now played around with it and messed around with the settings, I figured out what was going on. Turns out, the dark "shadow" on the glazing isn't a shadow on the glass so much as the dark interior of the building. Guess I can't fake it like I can with a more simplistic program like Sketchup. Oh Well. Thanks again for the suggestion.
help with shadows on elevations |
Fri, May 16, 2008 at 1:52:59 PM
Printing elevations with shadows. |
Fri, Nov 1, 2013 at 3:39:51 AM
Rendering glass in revit 2009 [ 1 2 ] |
Tue, Aug 4, 2009 at 12:02:07 PM
23
Help with shadows |
Wed, May 28, 2008 at 7:00:59 AM
V7 Shadows |
Wed, Dec 8, 2004 at 5:41:46 PM
Members: | 2102573 | Objects: | 23173 | Forum Posts: | 152290 | Job Listings: | 3 |
