81 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Staircase Railing cant extend to floor
Wed, Mar 26, 2014 at 7:49:38 AM | Staircase Railing cant extend to floor
abj123
hi every one, while am creating stair from ground floor to first floor, i need the stair railing to be extent to the floor, but i cant railing properly on my floor, it is created above the surface with some offset. please give me a solution. here am attaching the scrren shots
Wed, Mar 26, 2014 at 7:52:51 AM | Staircase Railing cant extend to floor
Your problem is you ended your stair with a tread.  Edit your handrail sketch and pull the intersection of the slope/flat back to the last riser.
Wed, Mar 26, 2014 at 8:18:47 AM | Staircase Railing cant extend to floor
abj123
But it is not coming properly, please find the attched picture
Wed, Mar 26, 2014 at 8:33:50 AM | Staircase Railing cant extend to floor
I don't think so.... Delete the portion of the sketch that is the flat.  Then see what happens.  The extent of the rail is only the sketch.  It will not go on up as you say.
Connecting two railings?
Sat, Aug 21, 2010 at 3:02:07 AM
Staircase railing problem
Fri, Jun 19, 2009 at 9:25:47 AM
extend railing past end post.
Wed, Dec 30, 2009 at 5:00:05 PM
Staircase Railing
Tue, Oct 22, 2013 at 3:26:35 PM
Problem with railing meeting top floor of stair
Wed, Jun 18, 2008 at 3:44:12 PM
Page generation time: 0.5417
