46 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Cloud Rendering Very Black
I have done multiple renderings in the Autodesk Cloud with Revit. I have one room that all the renderings I do are showing up with black dots. The odd things is I have copied the same floor plan (to make another option for the headboard) and have rendering with the copied floor plan and it turns out fine. I have checked the render settings (It is on Interior:Artificial only, as I want it). There are plenty of lights. I have done multiple views from the same room and they all turn out with black dots when I have fully rendered the room right next to it with no issues.
We can't help you except to say it looks like you have not done what you thought you did.
This would have been a great opportunity to use design options. Then the walls/fllor/ceiling and lights would have been the same and only the furnishings changed from design option to design option.
360 cloud rendering the lights like garbage |
Tue, Feb 26, 2013 at 3:20:23 PM
Rendering in cloud |
Fri, Jan 6, 2017 at 7:34:57 PM
Black walls in rendering |
Mon, Feb 1, 2016 at 3:22:22 PM
Cloud Rendering Services |
Mon, Sep 10, 2012 at 2:53:50 PM
higher DPI cloud rendering |
Wed, Feb 15, 2012 at 4:13:21 PM
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
