83 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Cable Tray Clearance
Mon, Mar 24, 2014 at 5:16:51 AM | Cable Tray Clearance
vinnygolfer
4.5 Stars: 4 Votes
in Revit 2014, is there a way to draw cable tray with clearance? the only way that i have found to show the space that i need is to simply make the tray bigger. but i would like to show the clearance with a 60% transparency. any ideas? the out of the box cable tray does not even allow you to go into the family editor.
Try to learn at least one new thing every day
Mon, Mar 24, 2014 at 10:25:19 AM | Cable Tray Clearance
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I don't think there is a means OOTB. At least with Ducts you can use the Insulation aspect. Not so lucky with Cable Tray.
Mon, Mar 24, 2014 at 10:44:48 AM | Cable Tray Clearance
vinnygolfer
4.5 Stars: 4 Votes
that's what i was afraid of. i also have the b-line models, but they don't do it either.
Fri, Jun 14, 2019 at 5:48:11 PM
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
Cable Tray- Revit MEP 2013
Fri, Oct 5, 2012 at 8:29:45 AM
Revit 2015 - Ladder Cable Tray
Mon, Feb 29, 2016 at 5:05:14 PM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
Page generation time: 9.3539
