42 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Scaling within Generic Annotation Family
2 Posts No Rating |
I am trying to make a key plan and I started it in a Generic Annotation. It is of a mall and I have it set so when it is loaded you can turn the visibility of each store on/off.
To make this I started the plan larger- I anticipated getting errors that the lines I was drawing would be too small for Revit- thinking that I could scale it all down once I had the filled regions done. Wrong!
From what I've been able to find online so far I should've started as a Detail Item and not a Generic Annotation. Is there any way to correct the scale of the symbol without having to do it all again?
Any help is appreciated!
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop? |
I think you should cut your losses and start over. There are many discussions on key plans here at RC. Search key plan. I believe autodesk also has a tutorial on creating key plans.
2 Posts No Rating |
Darn. I was really hoping there'd be a workaround- there are 40+ spaces to hatch!
I used all of the threads here to figure out how to do it, the scaling is the only part I ran into problems.
Generic Annotation with Family Category based parameter |
Mon, Sep 16, 2013 at 7:18:15 PM
Issue with annotation nested with generic model family |
Wed, May 25, 2016 at 9:46:10 AM
Annotation scaling within Familes |
Mon, Sep 24, 2012 at 7:17:25 AM
Nest Generic Annotation in Detail Component |
Wed, Mar 17, 2010 at 7:18:22 PM
Generic Annotation symbol |
Mon, Dec 5, 2011 at 4:02:48 PM
Members: | 2037311 | Objects: | 23017 | Forum Posts: | 152210 | Job Listings: | 3 |
