Forums >> General Discussion >> Revit Project Management >> Export Revit to DWG - pattern problem
Hey, when I export a file from Revit to Autocad, the pattern model does not stay the same, so it changes my floor layout and my walls layout. How can I fix that? Thanks
I have never seen this happen. This is probably a pattern origin problem. Is there any way this pattern may already be defined in AutoCAD?
Is this just the simple pattern created in Revit or did you use Hatchkit or something like that?
Its a simple pattern that I created in Revit. I tried aplying the patten in the material and in the anotation fill, both had the same problem.
Is your Revit up-to-date? You should always include the revit issue and updates in your posts.
oh, sorry! i use revit 2013
And your updates are ?????
I harp on this because it is very important! Updates are issued to FIX problems.
If you don't know this yet (AND YOU SHOULD) you can find out what updates under the question mark dropdown ... about - post that image. Don't just say your up to date.
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches? |
Wed, Feb 11, 2009 at 4:42:25 PM
Wall Ratings - Export to DWG for Consultants |
Mon, Dec 6, 2010 at 2:20:44 PM
Export 3d DWG issues |
Fri, Jun 28, 2013 at 8:27:02 AM
Export to dwg problem - I want it all in 1 file :) - please heeeelp |
Wed, Jan 23, 2008 at 4:36:53 AM
Dwg export: revit 2013 ignoring subcategories |
Thu, Jul 25, 2013 at 8:12:43 AM
Members: | 2120579 | Objects: | 23207 | Forum Posts: | 152300 | Job Listings: | 3 |
