39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> How to remove Topo lines in subregions
Thu, Mar 20, 2014 at 3:08:56 PM | How can I remove or hide the Topo lines in subregions
Userfile340
I started a project in Revit / Bldg Dsgn Suite 2014,  created a site drawing around the building that I had drawn... then created a subregion as a method of defining a driveway which I filled with concrete as a material. Then I placed topo points all around the whole site to reflect the grades of the actual building site, and so the subregion which is the concrete road now follows the contours of the site plan.  So when I create a 3D view which shows the contour lines they are present on the driveway area as well. Is there a way to turn them off or make them hidden in the just subregion so the driveway appears smooth with no lines showing?
( Please be kind...I have only been at this for a few weeks )
Edited on: Thu, Mar 20, 2014 at 3:44:19 PM
Edited on: Thu, Mar 20, 2014 at 9:43:46 PM
Fri, Mar 21, 2014 at 3:35:50 PM | How to remove Topo lines in subregions
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If you create a 'split surface' instead of 'subregion' you will gain independant control over the topo points on that driveway area as apposed to if the area is a subregion. This would at least give you better control so you could 'smoth it out' and not effect the rest of the yard. The split surface can be near the edge of the topo or it can be an island and surrounded by the remaining topo surface.
Fri, Mar 21, 2014 at 3:36:01 PM | How to remove Topo lines in subregions
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Sat, Mar 22, 2014 at 8:27:16 AM | How to remove Topo lines in subregions
Userfile340
Thank you for the information, I will try that.
lines on topo surface
Wed, Aug 3, 2011 at 8:37:21 AM
Subregions on Topography Take Ages to Process & Regenerate.
Mon, Mar 23, 2015 at 7:24:12 AM
Property lines on Topo surface
Tue, May 21, 2013 at 7:23:22 AM
Gaps between Subregions
Tue, Sep 23, 2014 at 11:08:36 AM
Topo Lines part 2
Tue, Feb 28, 2012 at 10:05:01 PM
Page generation time: 0.5266
