54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Link CAD - problems
Wed, Mar 19, 2014 at 5:02:48 AM | Link CAD - problems
magnuser
HiI have a problem with linking my cad. I have linked the cad, but I am not able to draw a slab, using the lines from the dwg. file. I am also wondering how I can hide unnessescary things like furnitures etc. I want to know if there is a quick way to just mark the "wall lines" from the dwg. file and put a slab directly on top.ThanksMagnus
Wed, Mar 19, 2014 at 7:04:43 AM | Link CAD - problems
First, never use the lines from a CAD file.  Revit demands that parallel lines are parallel by Revit's standards and CAD lines that appear to be parallel rarely stand up to Revit's requirements.  Angles also don't work.   So instead, sketch your slab edges over top of the CAD file.
If the furniture is on a seperate layer as it should be, you can turn off that layer in your VG.
Wed, Mar 19, 2014 at 7:22:30 AM | Link CAD - problems
magnuser
Is there a quick method for sketching the slab edges over the CAD file? Or do I have to draw the slab line by line? I remember after marking the edgdes of the CAD file I only had to click once and the slab would would pop up by itself. Also, I have hidden my CAD file in another level, and I can't seem til get it back on the screen. Is there a solution for this hickup as well?
Wed, Mar 19, 2014 at 7:38:31 AM | Link CAD - problems
I would draw by line starting in one corner.  If you know the exact dimensions then pay attention to your temporary dimensions and draw it exact.
Once you have one floor done, you can copy that floor to other levels - no need to re-sketch it.  Pick the floor - copy to clipboard, then paste to selected levels.
Wed, Mar 19, 2014 at 7:42:48 AM | Link CAD - problems
magnuser
Thank you!
Link CAD, Import CAD in the middle of space
Tue, Sep 21, 2010 at 3:43:47 PM
CAD inserts appear in as many copies in my manage link view
Fri, May 15, 2020 at 5:17:45 PM
Link CAD problems
Fri, Feb 1, 2019 at 6:08:03 AM
Problems with linked AutoCAD files
Thu, Jul 2, 2009 at 9:22:19 AM
Insert/Link CAD Advice
Wed, Dec 21, 2011 at 2:56:23 PM
Page generation time: 0.6072
