126 Users Online (125 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 2013 revit new sheets not opening in correct discipline
Tue, Mar 18, 2014 at 8:24:36 AM | 2013 revit new sheets not opening in correct discipline
minsky
1 Stars: 1 Votes
How do I get new sheets to open properly in a specific discipline.  they are all opening on a category at the below the discipline where I need them to be and I cannot figure out how to open them in the correct one or move the ones I've already created with the proper numbers.
Tue, Mar 18, 2014 at 8:51:38 AM | 2013 revit new sheets not opening in correct discipline
minsky
1 Stars: 1 Votes
Ha!  Found it.  Properties / category sort / *****
So endith the trick.
Tue, Mar 18, 2014 at 8:55:37 AM | 2013 revit new sheets not opening in correct discipline
Sheets are NOT sorted in the view area.  You can add a project parameter to sheets that you can use in your browser sort setup.
Linked Revit Model Sheets
Fri, Apr 5, 2013 at 12:04:29 PM
Can't find Sub-Discipline in Properties
Mon, Jan 27, 2014 at 5:24:23 AM
sheet index order with Linked models
Fri, Mar 11, 2016 at 2:33:54 PM
Filtering placeholder sheets by discipline in a sheet list
Thu, Jun 23, 2011 at 12:27:05 PM
Sub Discipline under Views?
Fri, Apr 17, 2009 at 2:21:22 PM
Page generation time: 2.1166
