104 Users Online (102 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Cut Pattern - Timber Columns in plan views to black ?
Mon, Mar 17, 2014 at 9:28:15 PM | Cut Pattern - Timber Columns in plan views to black ?
Reddrev
I did manage to do this a while back, but have forgotten (should have made a note).
The structural timber columns.  I would like them to be filled black, like i can with concrete columns, walls etc. I can't seem to locate the timber columns in the VG window.  Structural Columns and Column settings aren't doing it, nor is tructural framing etc.
Many thanks
Tue, Mar 18, 2014 at 7:32:56 AM | Cut Pattern - Timber Columns in plan views to black ?
3.5 Stars: 395 Votes
Right click on the column in plan..... I don't know if it is architectural or structural column, only you know that.  If structural, you can change the material and the material representation when cut.  If architectural, the column will assume the material of a wall if it touches one.
Tue, Mar 18, 2014 at 7:33:22 AM | Cut Pattern - Timber Columns in plan views to black ?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
WWHub beat me to the answer
Edited on: Tue, Mar 18, 2014 at 7:33:50 AM
Tue, Mar 18, 2014 at 7:41:46 PM | Cut Pattern - Timber Columns in plan views to black ?
Reddrev
Thanks for your reply,  after some trial and error, I also found that the "detail" must be medium or fine to activate the cut infill pattern on the timber column.
I am learning Revit, out here in China.  Revitcity and its members are just fantastic for my learning, thank you all so much.
Showing column cut on top of wall cut pattern
Tue, May 28, 2013 at 4:06:05 AM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
Black dots appearing in columns when using pattern override
Wed, Oct 24, 2007 at 10:27:51 AM
Revit 2008 - changing pattern overscaling color from gray lines to black
Tue, Nov 20, 2007 at 6:25:40 AM
ARCHITECTURAL COLUMN ISSUE
Wed, Feb 12, 2014 at 10:43:38 PM
Page generation time: 2.9060
