155 Users Online (153 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> dwg to revit exports as one object
Sat, Mar 15, 2014 at 8:01:50 PM | dwg to revit exports as one object
username8910
Hello there,
I am trying to import an autocad dwg file-3d map of an area to Revit, where in the autocad file you can obviously select it one by one building seperately. So i went on Revit, insert --> import cad and then got the map as one object. do you have any idea how can I split the object to smaller elements, so that i can select each building and edit them seperately..? also if there was a post like this before with the answer just copy the url . thank you in advance Smile
Sun, Mar 16, 2014 at 5:42:59 PM | dwg to revit exports as one object
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
A link is just that.. a link, you cannot modify it to move things around, if you want separate buildings you need to link them in separately.
Mon, Mar 17, 2014 at 7:26:48 AM | dwg to revit exports as one object
Also, uou can't edit CAD in revit unless you explode it and I suggest you don't do that.
Revit Exports DWG Sheet to 0,0,0 not correct coordinates.
Thu, Feb 23, 2012 at 9:43:34 AM
Sheet DWG exports appeat PINK in autocad
Wed, Apr 10, 2013 at 7:54:45 AM
solid object from 3D dwg
Thu, Apr 16, 2009 at 5:17:17 AM
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
Grid line problem (cad export)
Wed, Apr 11, 2012 at 7:18:20 AM
Page generation time: 2.8366
