69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Adding a Tail to Interior Elevation Tag
Fri, Mar 14, 2014 at 12:10:55 PM | Adding a Tail to Interior Elevation Tag
mjm223
3 Stars: 2 Votes
I'm trying to create an interior elevation tag that looks similar to a section tag (head & tail), but only has the detail number called out. Typically when we do interior elevations, the enlarged plan and all of its elevations are on the same sheet, so having an elevation tag that calls out the sheet number is a bit redundant.
I was able to successfully create the head, but I'm not sure how to create the tail.  Is it possible to add a breakable tail to an elevation tag? (By 'breakable' I mean the ability to split the tail line like you can with a section tag.)
Attached is a screenshot of the elevation head in action. I could just manually draw the tail with detail lines, but I was curious if anyone knew a more creative way to make the tail a part of the tag.
Fri, Mar 14, 2014 at 12:33:14 PM | Adding a Tail to Interior Elevation Tag
You could just use a modified section.  Yes.... the views will be stored under sections in your browser but so what?
Fri, Mar 14, 2014 at 1:10:11 PM | Adding a Tail to Interior Elevation Tag
mjm223
3 Stars: 2 Votes
That's very true. And section cuts do give me more freedom to reshape the crop boundary. You might be on to something here...
Interior Elevation Tag - adding Leader
Sun, Feb 17, 2008 at 8:36:29 PM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
Modifying Interior Elevation tag
Thu, Oct 21, 2010 at 8:32:48 AM
Interior Elevation Tags
Wed, Oct 9, 2013 at 2:23:36 PM
Changing the size of the interior elevation tag
Wed, Dec 20, 2006 at 12:26:41 PM
Page generation time: 0.9500
