Forums >> Revit Building >> Technical Support >> How do I add crown molding to wall cabinets?
I am using Revit 2012 and having issues trying to add a sweep to the tor of cabinets. Please help.
How are you adding the sweep? Within the project or in the family?
Do you add the sweep by picking the edges or do you draw the path?
You give us NO information. as KimTaurus said. Another great question is what are your issues? Hard to help you when we don't know what is wrong so communication is key.
Tried both, no success?
Then your process is wrong.
I am picking edges in the family editor but it will not finish my path?
Here is a cabinet wih a sweep. Examine it and that may help you.
Do you have all your updates?
If you installed 2014, it sometimes messes up 2012.
Edited on: Wed, Mar 19, 2014 at 12:40:05 PM
Thanks WWWHub I will check it out.
What about creating that in the revit model? I can only figure out how to create a wall sweep. im thinking it needs to be some kind generic model sweep? Please help
Model in place - sweep.
