127 Users Online (126 Members):
Forums >> Revit Building >> Technical Support >> Butt-jointed curtain corner - no mullion?
7 Posts No Rating |
I'm trying to make a curtain glazing system go round a 90deg corner with butt-jointed glass. That is, I don't want a corner mullion, the curtain panels should extend right to the edge - and join properly if possible. See attached for the offending corner.
Any clues?
I don't want to create a custom family if at all possible, as there are many unique windows in this building that I'd like to be able to easily lay out with curtain grids.
You have to create a new curtain wall family (see attached). After you load it into your project go to your curtain wall properties Edit/New and change your curtain wall to one of the 4 types in the imported family. If you want to use a combination of types just create several similar curtain walls. Hope that helps.
1 Posts No Rating |
how do you give a material to this family
13 Posts No Rating |
"You have to create a new curtain wall family (see attached). After you load it into your project go to your curtain wall properties Edit/New and change your curtain wall to one of the 4 types in the imported family. If you want to use a combination of types just create several similar curtain walls. Hope that helps." hmm, wheneve i try to load this .rfa REVIT 2010 drops it automatically into the "windows" folder, rather than (i suspect) the profiles/curtain wall folder. is this correct?
This i don't understand, can you be more explicit??
butt-glazed corner with mullion |
Wed, Mar 14, 2007 at 6:35:43 PM
Horiz mullions wont clean up because of angled corner mullion |
Wed, Oct 1, 2014 at 8:43:20 AM
How to build a butt joint corner window family? |
Thu, Mar 27, 2008 at 12:21:14 PM
Create NEW Curtain Wall Mullion FAMILY |
Fri, Mar 13, 2015 at 9:59:35 PM
Curtain wall corner mullion |
Mon, May 15, 2017 at 8:33:52 AM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
