65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rainscreen/wood/vertical...how to?
Mon, Mar 10, 2014 at 4:49:02 PM | Rainscreen/wood/vertical...how to?
inOregon
Hello,
First post here...very new to revit.
I unsucessfully searched for answers to the following question:
How do I best model a vertical wood rainscreen, with 1" square slats, and 3/8" spacing between?  Seems basic enough, but I am stumbling on several issues.
I am thinking this might be best done with a curtain wall family, yes?  My hope was simply attach to top of my wall, following the rake of the roof.  But, I am not sure how to do so, without glass being involved.
I see there is a family created by another rc user but I couldn't get it to function as I need, and it needs more detail I wish to add.
Any help is appreciated.  I am running revit 2013.
Thank you.
Tue, Mar 11, 2014 at 7:27:54 AM | Rainscreen/wood/vertical...how to?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would probably use a curtain wall. Your wood slats will be your mullion profile and your glazing will be your spacing however you will set your curtain panel to none so that you don't actually have glazing
Tue, Mar 11, 2014 at 11:36:10 PM | Rainscreen/wood/vertical...how to?
inOregon
Awesome.  So simple.  Though, I needed to change the Curtain Panel drop-down choice to Empty System Panel:Empty fo the glass to completely dissapear. The None option still left panels in place.  Anyway...
Thank you.  Very helpful.
Vertical wall pannels... help with rendering
Thu, Apr 28, 2011 at 10:50:13 AM
Vertical line in exterior rendering
Thu, Feb 23, 2006 at 3:29:26 PM
Brick Coursing Changing to Vertical At Wall Opening
Mon, Dec 24, 2012 at 2:17:39 PM
Wood floor way too shiny.
Tue, Dec 14, 2010 at 7:32:40 AM
help...Wood plank railing gaps
Wed, Aug 17, 2011 at 10:12:06 PM
Page generation time: 0.2901
