88 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> concrete window sill and header category?
Sun, Mar 9, 2014 at 10:44:39 PM | concrete window sill and header category?
bigbrother
hi guys,
i just wonder to which category should I make the concrete window sill and header.  The window protrudes several inches from the wall, which causes deep sill and header.  I tried to make them under General Model category but i couldn't get rid of the edges when i join them with the wall (siding).  Also, I coudn't attach the top / bottom of the wall (Siding) to it, probably because it's just under General Model and not either floor or roof.  If I don't succed on getting rid of those unneccesary lines, they will show on elevation and may cause mistakes on the design.
Bytheway, I'm using Revit Architecture 2013.
please see attached images.
thanks.
129525_concrete_window_sill_and_header.png129525_concrete_window_sill_and_header_3D.png
Mon, Mar 10, 2014 at 6:26:20 AM | concrete window sill and header category?
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
I assume you made the sides as walls and the top and bottom a floor/roof? Or is this protruding window modelled as one family?
You could always override the linework in elevations to prevent mistakes during construction. This feature is under the tab Modify.
Another way is to add a finish to the exterior made as a thin wall. This will cover the sides of the roofs and floors.
Mon, Mar 10, 2014 at 7:24:07 PM | concrete window sill and header category?
bigbrother
Thanks KimTaurus.  I'll try your suggestions and see where it'll get me.
Until next time. :-)
Need help with window?
Tue, Nov 24, 2009 at 1:38:34 PM
Arch Top Window Header
Mon, Mar 5, 2012 at 3:43:09 PM
Sloped interior window sill in wall
Tue, Feb 14, 2012 at 3:30:27 PM
Window with angled sill
Fri, Nov 16, 2012 at 10:49:58 AM
Problems with visibility of Header and door openings
Fri, Jul 26, 2013 at 11:05:24 AM
Page generation time: 2.8397
