74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> 1 1/2 story house
Revit guru's: We're working on a 1 1/2 story house (Revit 2013) and we're running into a little trouble on the "1/2" story floor plan. (This 1/2 story is under a 10/12 roof). Basically, the problem is that some of the walls closer to the perimeter of this 1/2 story show up as "projection" instead of "cut" because they're not actually being cut in the view. We could adjust the view's cut elevation, but then other objects don't appear as you would like.
This means the wall components/layers don't show up (i.e. siding, plywood sheathing, stud framing, gyp. bd., etc.). Instead, all you get are the two lines indicating the outer-most sides of the wall. We really want these components/layers to show up, so we could just draw those in with old-school lines. Surely you guys have come across this one before. What do you suggest?
Look into plan regions. You can read about how to do those in your HELP.
Thanks for your help. I will happily look this up in help, but I wouldn't have known what to look for had I not asked here. Thanks again.
How to model floor joists correctly in 2 story residential |
Sat, Nov 28, 2009 at 8:35:09 AM
Two-story windows, please help! |
Wed, May 9, 2012 at 7:47:45 AM
Roof doesn't show up on floor plan |
Tue, Feb 5, 2019 at 3:45:30 PM
2 story areas |
Tue, Jul 29, 2008 at 12:31:16 AM
New sections views show every story in my 75 story project! |
Mon, Dec 23, 2013 at 6:43:12 PM
Members: | 2017104 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
