46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Object rotates when copied
Fri, Mar 7, 2014 at 2:25:16 PM | Object rotates when copied
Kentp419
Revit 14LT.  Working on soffit framing on a wood truss structure.  I've copied by soffit framing members from truss to truss with no problem.  When I try to copy the same objects to rafter members where the span was too short for trusses, they rotate automatically.  I've tried clicking/unclicking the "contrain" box, but the outcome is the same.
Sweep profile rotates
Tue, Oct 23, 2012 at 2:37:25 PM
Material Orientation Problem
Mon, Apr 6, 2009 at 2:10:13 AM
Change a copied lever to an original level
Mon, Apr 19, 2010 at 11:26:42 AM
3D rotate view with mouse
Wed, Dec 2, 2009 at 1:14:37 AM
What is the best way to Add a custom mass object to your project
Tue, Oct 21, 2014 at 7:13:46 AM
Page generation time: 0.3739
