98 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> exporting to dwg - load layers from standards
Thu, Mar 6, 2014 at 8:41:46 AM | exporting to dwg - load layers from standards
ledgewood33
I would like to export to dwg using my own layer standards. I see that you can load settings from file. it looks for a .txt file. how do I create a layer standard into a .txt file? is it something I need to do in CAD?
Thu, Mar 6, 2014 at 8:50:47 AM | exporting to dwg - load layers from standards
As with most things in Revit you can find the way by looking in your Help.  That would refer you to this:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-E0B73981-9496-43CD-A358-581FEF3A3008
Thu, Mar 6, 2014 at 9:15:53 AM | exporting to dwg - load layers from standards
ledgewood33
in the help menu I could not find where I can create a .txt file that it is searching for to map.
Thu, Mar 6, 2014 at 9:21:02 AM | exporting to dwg - load layers from standards
ledgewood33
how do I create an "export layer file (*.txt)" based on my office standards layering system
Thu, Mar 6, 2014 at 10:21:03 AM | exporting to dwg - load layers from standards
In 2014 (you don't say and I will not now look elsewhere)  the file is in C:\ProgramData\Autodesk\RVT 2014.  Copy that to another location, rename and edit as required then use the browse to find it.
Thu, Mar 6, 2014 at 10:51:18 AM | exporting to dwg - load layers from standards
ledgewood33
sorry about that. I am using both 2013 & 2014. so I followed the path that you provided and did not see any .txt files that are related to the export .txt. is there a specific file name that I can look for?
also is there a way to create this .txt file from autocad based on my layers that I want to use?
Thu, Mar 6, 2014 at 11:16:46 AM | exporting to dwg - load layers from standards
exportlayers-dwg-AIA.txt
Do a search for that file from exployer NOT REVIT! .... You will see different ones in different places.  The location I gave is 2014.
I don't know how you would do it from autocad.....
Tue, May 5, 2015 at 6:48:37 AM | exporting to dwg - load layers from standards
keroosheh
ia can,t find this file, too
Tue, May 5, 2015 at 7:58:50 AM | exporting to dwg - load layers from standards
If you had read the other posts in this thread, you should have realized that the location is dependent on the Revit version you are using.  Please be respectful and include your Revit version in your question.
Thu, Jul 16, 2015 at 5:25:00 PM | exporting to dwg - load layers from standards
iamian33
iamian33 Avatar
The company I now work for has a well-established CAD layer standard.  I am tasked with creating settings for Revit 2015 to export our Revit work to the company's CAD layer standards.
Is there a way to export the layer standards from a DWT/DWG file and import this into Revit through the Modify DWG/DXF Export Setup?  It needs to be a TXT file for Revit to import.
thanks in advance
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Keep .dwg Layers when exporting .rvt to .dwgPlease
Wed, Feb 24, 2016 at 9:28:00 AM
Imported layers still active when exporting
Fri, Feb 26, 2010 at 8:44:41 AM
DWG export: room tags to different layers
Tue, Oct 7, 2014 at 7:27:54 AM
Keep layer names when exporting to DWG
Mon, May 13, 2013 at 7:48:11 AM
Revit Export to .DWG - Walls onto different layers?
Mon, May 18, 2009 at 5:09:07 PM
Page generation time: 2.0589
