54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Choosing Which Objects Light Can Cast Shadows On
Wed, Mar 5, 2014 at 8:52:20 AM | Choosing Which Objects Light Can Cast Shadows On
jsego
Hello,
I am using Revit 2014.  I have a series of indirect fixtures hanging below trusses and when I render it, it casts crazy shadows across the walls and ceiling.  Is there a way that you can choose which objects the lights cast shadows on, or any other suggestions on how to fix this?  I am using studio lights right now.  My main problem is that I am working with a linked MEP file and the lights are not turned on in the file.  For some reason, even when I edit the MEP file, the lights still won't come on so I have to place my own.  They are turned on in VG as well.  Any advice is helpful.
Thank you!
Thu, Mar 6, 2014 at 1:43:54 AM | Choosing Which Objects Light Can Cast Shadows On
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
Check you Object Styles and material parameters for the windows.
It's possible the set material has a grey fill in the Graphics tab.
Nvm: wrong post.
Edited on: Thu, Mar 6, 2014 at 1:48:36 AM
Thu, Mar 6, 2014 at 7:29:41 AM | Choosing Which Objects Light Can Cast Shadows On
In many cases, MEP lights are not functioning lights for renders.  You can turn off the visibility of linked file components under the view VG / Linked Revit/ custom ....and the linked file VG settings
Lighting through solid
Tue, Feb 9, 2010 at 8:28:30 AM
convert generic wall and roof to cast colored shadows
Sat, Oct 20, 2012 at 6:05:41 AM
Linked Models don't cast shadows???
Mon, Sep 27, 2010 at 8:48:08 PM
Shadows on plan view cast from cut plane
Wed, Sep 24, 2008 at 9:24:33 AM
Shadows on floor plans
Sat, May 18, 2013 at 7:41:41 PM
Page generation time: 1.0851
