73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Inserting stringer profiles
Tue, Mar 4, 2014 at 12:31:59 PM | Inserting stringer profiles
RDALIVAJR
I am trying to make a floating staircase which is supported by a hollow tube stringer. But I can't seem to figure out how to insert stringer profiles into the project. I've seen a few threads where people wanting channels are told to just upload the construction template which has channels already preloaded and I notice a structural template has I beams preloaded, but I want to use a hollow tube. Unfortunately inserting a profile just places it in generic profiles and it does not appear in the stringer options even when I edit the profile to be used as a stair support.
I don't really want to use the railing work around, so I was wondering if anyone else has run into this problem and found a solution.
I'm using Revit 2014.
Tue, Mar 4, 2014 at 1:26:10 PM | Inserting stringer profiles
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Load the profile you want.  Its under Profiles>Framing>Steel>HSS.  You will need to actually go into the family and make the profile usage a stair support however for it to work in a stair.
Tue, Mar 4, 2014 at 5:19:54 PM | Inserting stringer profiles
RDALIVAJR
That's the thing, even when I do that it it doesn't show up in that drop down.
Wed, Mar 5, 2014 at 7:23:54 AM | Inserting stringer profiles
  The profile needs to be assigned "generic" and not assigned to stairs.  Try a new project using the commercial template.  You will find the channel profile there.
A guide to inserting profiles?
Thu, Dec 20, 2007 at 4:17:45 PM
Stair Shaft Creation
Sat, Nov 15, 2008 at 7:38:05 AM
Stringer Haunch (level off) at top of flight
Wed, Dec 14, 2011 at 2:03:07 PM
Stringer as rail profile problem
Tue, Mar 25, 2014 at 8:27:15 AM
Railing and Baluster Profiles not inserting on centerline?
Fri, Oct 5, 2012 at 2:26:21 PM
Page generation time: 0.2222
