153 Users Online (152 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> curtain system
Mon, Mar 3, 2014 at 12:23:25 PM | curtain system
PaulM3357
After placing a curtain wall (Exterior Glazing), I added mullion to the grid location. After this modification, I cannot select or modify this curtain wall as a single component. I can only select a single or a group of component in this curtain wall. The length and height of the curtain wall cannot be change by grip edited.
Is there a work arround for this scenerio?
Thanks is advance for your comments!
Mon, Mar 3, 2014 at 12:28:26 PM | curtain system
You are doing something wrong because adding a mullion will not do what you say is happening.
Tab over the CW and you will see the location line and grips.
Edited on: Mon, Mar 3, 2014 at 12:29:47 PM
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:48 PM
Curtain system from mass - Revit 2014
Fri, Jun 17, 2016 at 12:20:50 PM
Timber curtain wall system
Wed, May 8, 2013 at 7:40:35 AM
Curtain System by Face
Tue, Nov 8, 2005 at 9:07:19 PM
Curtain system
Tue, Oct 24, 2006 at 10:18:58 AM
Page generation time: 0.9406
