70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> CAST IN PLACE STAIR PROBLEM
Mon, Mar 3, 2014 at 9:03:38 AM | CAST IN PLACE STAIR PROBLEM
LOSpistos
Hi,
please find attached the image of the stairs which havent displayed properly. Im not sure if its some revit bug or the problem of the stair properties.
The landing and some of the treads are missing the thickness and i really dont know what is causing the issue.
Many thanks for help
Luba
Mon, Mar 3, 2014 at 9:05:08 AM | CAST IN PLACE STAIR PROBLEM
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This looks like it could be a graphics card problem.
Mon, Mar 3, 2014 at 9:19:30 AM | CAST IN PLACE STAIR PROBLEM
What Revit?  What updates are installed?
This was a problem with monolithic stairs awhile back but I think the updates fixed it.
Mon, Mar 3, 2014 at 9:22:46 AM | CAST IN PLACE STAIR PROBLEM
LOSpistos
Hi,
im working in Rvit 2014 and how can i find out which updates are installed? Smile
Luba
Mon, Mar 3, 2014 at 9:25:18 AM | CAST IN PLACE STAIR PROBLEM
Under the ? dropdown.... About.
Mon, Mar 3, 2014 at 9:36:18 AM | CAST IN PLACE STAIR PROBLEM
LOSpistos
So i find the about dropdown menu but not sure if its the right one..Its in attachment.
Mon, Mar 3, 2014 at 9:42:56 AM | CAST IN PLACE STAIR PROBLEM
It is the dropdown at the question mark:
If 2014 - make sure you have Revision 1 installed.
Mon, Mar 3, 2014 at 9:44:48 AM | CAST IN PLACE STAIR PROBLEM
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Just to add to WWHub there are 2 releases that are available with 2014, make sure you install 1 and then 2.
Mon, Mar 3, 2014 at 10:02:39 AM | CAST IN PLACE STAIR PROBLEM
LOSpistos
Mon, Mar 3, 2014 at 10:04:59 AM | CAST IN PLACE STAIR PROBLEM
LOSpistos
Im in the work so i need to ask our IT support 2morrow cuz none of them is here today. Then I will see..
but thank you very much guys for ur help anyways!!
Mon, Mar 3, 2014 at 10:08:30 AM | CAST IN PLACE STAIR PROBLEM
LOSpistos
I cant install any updates as i dont have the administrator login details.
Wed, Mar 5, 2014 at 4:17:44 AM | CAST IN PLACE STAIR PROBLEM
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
All of radial treads should have same angles between each other in this case.
Here is a blogpost about this issue.
http://plevit1.blogspot.kr/2013/09/stair-landing-with-treads.html
hope this helps.
want more?
You can get more tips at Enjoy Revit
Simple Stair Nosing error
Thu, Mar 5, 2015 at 9:15:25 PM
Floating Tread Stair
Mon, Nov 6, 2017 at 5:17:59 PM
Revit Structures 2010 Material Takeoff Schedule
Mon, Dec 6, 2010 at 8:47:55 AM
Smart Tags - Cast In Place Concrete Panels
Thu, Sep 12, 2013 at 8:41:33 AM
Problem witch stair visibility
Wed, Apr 9, 2014 at 7:08:59 AM
Page generation time: 1.5726
